magnus effect
Old   December 19, 2004, 02:10
Default magnus effect
jackie
Hi all,
I'm a newer in Fluent program. I'm going to simulate a flow across a very long rotating cylinder (Magnus effect). I like to siumulate it as a 2D flow so, I would like to know can I use a rotating frame in 2D simulation? or it's more easier to use the other method. Could anybody give some sugestion please?
Thank you in advance?
Jackie
Old   December 19, 2004, 18:57
Default Re: magnus effect
Mani
I am not a Fluent user, but I read this as a fairly general question. There is no need to use a rotating reference frame in your case, in fact, it will only complicate things. If you know how to set up a computation with a stationary (non-rotating) cylinder, then the rotating cylinder should be easy to do. You only need to assign the correct boundary conditions, i.e. the velocities of the wall grid points, on the cylinder surface. Everything else is the same as in the stationary case, and the grid is also stationary.
How to create rotary domain for Magnus effect vovogoal CFX 0 March 22, 2009 15:22
VOF and strong surface tension effect phsieh2005 Main CFD Forum 1 August 30, 2005 06:56
magnus effect benoit FLUENT 1 June 4, 2002 04:00
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
Magnus Effect Model Dahvid Brown FLUENT 1 February 24, 2000 10:59
