ti-menu-... in (define... = error?
Old   December 30, 2004, 11:33
Default ti-menu-... in (define... = error?
Chris Bailey
I guess this question relates to the behavior of ti-menu-load-string inside a Scheme definition.
This trivial example works (it closes a graphics window):
(ti-menu-load-string "/display/close-window 1")
and it also seems to leave a boolean as its result.
But this doesn't:
(define shell (ti-menu-load-string "/display/close-window 1") )
(shell)
It closes the graphics window then gives this error and dies:
Error: eval: invalid function
Error Object: #t
I think the Scheme eval procedure is choking on the boolean that ti-menu... returns, and somehow I need to eliminate it, but that's just a guess.
Big thanks for any help for this new user!
Old   December 30, 2004, 14:36
Default Re: ti-menu-... in (define... = error?
Chris Bailey
Whoops - found it - I should have said
(define (shell)... instead of
(define shell ....
Just a newcomer's mistake.
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
