How to program TUI when prompts may vary?
Old   December 31, 2004, 11:57
Default How to program TUI when prompts may vary?
Chris Bailey
How is it best to program the Text User Interface given that the prompts may vary from situation to situation? For example in the program below, which does work, I read and analyze several different mesh files whose names contain a number that increments. In two places (they're commented) I have to add extra "dummy" operations to cause a known number of prompts so I can then answer them. Is there a less klunky way to do this???
(define filename1 "/file/read-case/ P:\a\fluent\20041227\multimesh9\\")
(define filename2 "")
(define filename3 "1")
(define filename4 ".msh y")
; Later must answer y to "discard mesh" so need one to discard on first pass
/file/read-case/ p:\a\fluent\simple.msh
(define (analyze_flow)
(ti-menu-load-string (string-append filename1 filename2 filename3 filename4))
(ti-menu-load-string "/define/boundary-conditions/velocity-inlet v_inlet n n y y n 1.22")
(ti-menu-load-string "/solve/initialize/set-defaults pressure 0")
(ti-menu-load-string "/solve/initialize/set-defaults x-velocity 0")
(ti-menu-load-string "/solve/initialize/set-defaults y-velocity 0")
; Don't know if flow field exists so initialize (which may fail), iterate (which won't), reinitialize y
(ti-menu-load-string "/solve/initialize/initialize-flow")
(ti-menu-load-string "/solve/iterate 1")
(ti-menu-load-string "/solve/initialize/initialize-flow y")
(ti-menu-load-string "/display/set/contours/filled-contours? y")
(ti-menu-load-string "/display/contour pressure , ,")
(ti-menu-load-string "/display/set/overlays? y")
(ti-menu-load-string "/display/vector velocity mass-imbalance , , , ,")
(ti-menu-load-string "/solve/iterate 5")
(ti-menu-load-string "/solve/iterate 40")
(ti-menu-load-string "/display/vector velocity mass-imbalance , , , ,") )
(define counter
(lambda (n)
(do ((i n (- i 1)))
((zero? i))
(set! filename2 (format #f "~a" i))
(analyze_flow)
(counter 3)
Chemkin Forums? PSR.f program help? johnjohnmulley Main CFD Forum 2 August 5, 2013 07:53
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
Which opensource and free CAD program? Xwang Main CFD Forum 1 October 24, 2010 17:29
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 11:55
Define animate using TUI Zurlugh FLUENT 1 July 24, 2008 08:55
