Split boundary
Old   February 3, 2005, 02:07
Default Split boundary
Thomas
can someone tell me how to separate a straight boundary (pressure outlet) in two or three boundaries.
Or can I do this in Gambit, without loosing all my input data of fluent?
Old   February 3, 2005, 07:49
Default Re: Split boundary
Giordano Bruno
I think you can use Grid->Separate->Face in Fluent without loosing your input... I used Grid->Separate->Cells and it should work in the same way.
Greetings,
Giordano Bruno
Old   February 4, 2005, 07:16
Jason
You can mark cells by region. You can mark a hexagonal, cylindrical, or spherical group of cells. This is under adapt -> region. Instead of adapting though, just select "mark". Then you can go to Grid -> Separate Faces, and choose separate by Mark.
Due to the limited ways of marking by region you're limited in how many ways you can separate the face. Also, marking cells marks cells whose cell centers fall within (or out of if you selected outside in the options for region adapt) the region you define. Depending on your mesh, this usually doesn't create a clean edge, but if you don't need it to be exact, then this method works pretty well.
Hope this helps, and goodluck Jason
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
