boundary conditions
Old   January 29, 2005, 05:32
Default boundary conditions
OB
I have a solid zone defined as x min=0mm, x max =100mm, y min= -20mm, y max =0, And another fluid zone (air) on the solid zone (on top) defined as x min=0mm, x max =100mm, y min=0mm, y max =2.5mm, In the y=2.5mm .I want to put a fluid as boundary conditions (mass flow for example) this jet flow was displaced in the x direction (velocity v= 4mm/s), in this case we use an UDF, the radius of this jet is for example r=3mm .This fluid injected was put on the solid zone after the passage in the fluid zone (air). It is possible to do this approximation, and which model can we use (VOF….) Thank you very much.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
