Heat transfer through a chimney
Old   January 19, 2005, 09:38
Default Heat transfer through a chimney
ocy
Hello all,
I am modeling 2D heat transfer through a chimney. The wall of the chimney is taken into consideration and the continum boundary type given is 'solid'. While the interior of the chimney is given a continum boundary type, 'fluid'
For the boundary condition at the external part of the wall exposed to ambient, I used convection.
Does anyone know what i should put as boundary condition for the internal part of the wall that is exposed to the flow of hot air in the chimney?
Thanks in advance!
The only options available are: heat-flux, temperature or coupled.
Old   January 24, 2005, 22:16
Default Re: Heat transfer through a chimney
Jeffery
You should choose coupled
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
