Difference between 2D and 3D !
Old   January 25, 2005, 03:59
Default Difference between 2D and 3D !
Christophe
Hi everybody !
I would be very pleased if someone could give me information about a "possible mistake" I made in a modelisation.
I made a 3D case modeling a combustion in a closed volume. Source is a exit nozzle and boundary condition is "pressure inlet" (I know P, T0 and Pstat). I get the convergence and analyse pressure and temperature fieds on the wall in front of the exit source (3,00 m away).
I try to realize an equivalent in 2D with an axisymmetric case. The boundary condition "axis" is along the x-axis. I kept the source data defined for 3d case. I mesh the plane with size-function along x that is to say along the flow.
The trouble is that I do not get the same result in pressure and temperature (20% different) and the time the flow impact the wall target is greater in the 2d case (6 ms) than for the 3d (3.5 ms).
What could be the matter ? Time-step ? Use of a size function ?
I hope this trouble could find a answer...
Thanks...
Old   January 25, 2005, 12:21
Default Re: Difference between 2D and 3D !
ap
First of all, try to reproduce the mesh you used in 3D in the Axi case.
However, I had similar problems in many cases. Usually a flow is not fully symmetrical, so using the axi solver might not be appropriate.
Hi, ap
Old   January 26, 2005, 03:10
christophe
Thanks for your answer.
In fact I am not sure that the size function used in the 2d case is the same than in the 3D.
I will check it now.
Christophe
