cells less than one
Old   January 25, 2005, 06:15
Default cells less than one
Andrew Garrard
I am looking at some UDF code that someone gave me and I am a litte confused, it is show below. My questionis why would a cell index (c1) be assigned a negative value (i.e. < 0). Any help would be super.
DEFINE_UDS_FLUX(conv_fluxes, f, thread, eqn)
cell_t c0, c1;
Thread *tc0, *tc1;
c0 = F_C0(f, thread);
tc0 = THREAD_T0(thread);
c1 = F_C1(f, thread);
tc1 = THREAD_T1(thread);
if( c1 < 0 )
return one thing
else
return another
Old   January 25, 2005, 08:29
Default Re: cells less than one
Luca
According to me the cell_t index goes from 0 to n-1 cells. So the first if will never be executed. Luca
Old   January 26, 2005, 05:41
Andrew Garrard
I ran this code with a Message if c1<0 and it produced results. so at some point c1 does adopt a negative value. When this happens c1 adopts the value of -1 according to the output line. I am guessing this must be something to do with the boundary, but some more insight would be very helpful.
Old   January 26, 2005, 05:48
Luca
Try to discover where is the cell with index -1. For example export its node position with the macro NODE_X(node). I had never come across a negative index. Maybe it means something... Is it the only negative index you found? Please let me know. Luca
Old   January 26, 2005, 05:54
Luca
AH! Maybe C1<0 means that no c1 cell exist. If you're applying your function on a boundary face-thread, there's no C1 cell adjacent to it, only a C0 cell. I used the macro BOUNDARY... reported on the UDF guide. Let me know what you discover.Luca
Old   January 26, 2005, 07:29
Andrew Garrard
-1 is the only negative index retuned and from returning F_CENTROIDS, it looks like you are right. if c == -1 then it appears to be a boundary face and hence c1 dosen't exist.
Thanks.
Old   January 27, 2005, 05:15
Luca
OK then, we learned something more about UDF programming... Have a good day,Luca
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
