MDM Error
Old   January 28, 2005, 04:24
Default MDM Error
mAx
Hi, I am setting a MDM calculation on an hydraulic valve. I am using an UDF (Fluent Tutorial 2d Valve Motion) which automaticaly calculates the piston displacement by integrating the force difference between piston's force and spring force (behind the piston). The MDM strategy is simple: I create a layering band in front of my piston, and I destroy another layering zone behind the piston as the piston moves. I already tested it with 1/16 from my model (ie: 22.5 degree revolution symmetry) without modeling the layering to destroy. Results are great, but as I compare them with the experiments I get with Fluent, the dp should lightly grow with the massflow (linear profile). With my results the dp falls lightly. I tried to simply include the seals effects in the udf but it doesn't change anything. So I try now to simulate the half model (with the right inlet and outlet) meaning I have to include the destroy layering band. As I test the piston motion in fluent with a profile (piston motion describes by profile) I get perfect motion (eg: adding layers and suppressing layers). But as I switch with the udf motion, I got the following error:
Warning: storage skewness not shared by zones 30 and 17. Error: coalesce_rib_faces: can't interpolate data, zones of different type detected.
(I have no interpolation and my skewness is ok. Grid check ok just before I Iterate) Does anybody already have this message? What is the solution? Thanks mAx
Old   May 31, 2022, 10:25
Smile Answer
Amir
Master312 is on a distinguished road
Originally Posted by mAx
;117492
hello dear
you must change your boundary condition of "walls to interface" in "direction" of your interface. in other words you must change all boundary conditions that slide through "motion wall" to interface and then define them in manual interface. in the last you have all boundary conditions of slider with "interface" mode, "no" part of that.
Master312 is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
