January 28, 2005, 05:24 |
GRADIENTS
Hi all! I have a problem with gradients. Why using the coupled solver it's not possible to obtain the gradient? The solver gives me a segmentation error but gives no problem If I want to know the reconstructed gradient of the pressure. Please help. I hope somebody can gimme some suggestion. Luca
January 28, 2005, 10:38 |
Re: GRADIENTS
I had a similar problem. Are you shure that you use: solve/set/expert and "yes" answer to the question Keep temporary solver memory for beeing freed?
see UDF manual, pag 5-10 |
January 28, 2005, 10:43 |
Re: GRADIENTS
Yes I'm sure. Anyway I noticed the it works even if I don't set yes...it's strange, isn't it? I discovered that some gradients can be found, some others not...This happens even when I set the segregated.
Velocity Gradients or Pressure Gradients? | owayz | OpenFOAM | 9 | August 14, 2012 13:09 |
Large pressure gradients = anisotropy??? | cfd_enthusiast | Main CFD Forum | 0 | February 9, 2010 11:09 |
density gradients in CFX post | prabhu | CFX | 1 | June 12, 2006 06:47 |
extract velocity gradients with cfx4.2 | franco belosi | CFX | 1 | November 28, 2002 18:41 |
Calculation of Gradients | Bo Jensen | Siemens | 0 | July 10, 2001 07:14 |
