Reaction in a Bubble Column
Old   February 12, 2005, 01:17
Default Reaction in a Bubble Column
Ozone
I want to study ozonization reactions and also the hydrodynamics. For the time being, we want to start with a simple phenomenon: Ozone-rich air will be bubbled into the water, and in the gas phase, the ozone will decompose to oxygen. Due to the increase in the number of moles, the volume of the bubbles will increase i.e. the bubble hold-up will go on increasing. We want to study how this effects the hydrodynamics.
Can you please suggest:
(1) Which reaction model I should choose? Volumetric reactions or particle surface reactions?
(2) This should be a multiphase model; but when I choose e.g. mixture model, the option for reaction does not come.
Please suggest a way out.
Ozone
Old   February 13, 2005, 08:02
Default Re: Reaction in a Bubble Column
ap
You should wait for FLUENT 6.2, which will implement the model you need.
FLUENT 6.1 doesn't allow to model chemical reaction in the Mixture or in the Eulerian models.
Regards, ap
Old   February 14, 2005, 01:25
Ozone
Thanks a lot. I will look for the updates to be released. Any idea when this version is likely to be available?
Old   February 14, 2005, 14:28
ap
If I'm not wrong, it should be released in this (feb) month.
ap
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 06:01
bubble column ken FLUENT 1 June 30, 2013 01:18
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
