2D swirler setup
Old   February 14, 2005, 05:54
Default 2D swirler setup
tomas
Can anyone at least suggest to me someway of setting up the following problem in Fluent? I have a gas combustor which uses a swirler to rotate the incoming flow about the centerline axis of the combuster (lets say the combustor has a can-shape). I would like to model this as 2D axisymmetric with swirl. I set up inflow and outflow boundary conditions into and out of the can combustor, but what boundary conditions can I use to represent the swirler, which is basically rectangular shaped, located 1/3 downstream of the inflow and must change the path of the flow? Any help would greatly be appreciated. Tom
Old   February 14, 2005, 15:18
Default Re: 2D swirler setup
arashshahin
i think you must have a 3d model for swirl and i think whith 2d model swirl modeling is impossible. could you send me your 2d model dwg. then may be i can help you. bye
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Setup Cell Error in Fluent on Workbench tolu FLUENT 1 September 12, 2013 13:28
2D setup and 2D profile data file in CFX10 Se-Hee CFX 3 October 30, 2006 09:49
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 08:27
3D swirler modelling sarat FLUENT 5 June 13, 2005 04:55
