February 17, 2005, 19:15 |
Laminar pipe flow
Why do I get worse results compared whit analytical results when I refine the mesh? I'm simulating laminar pipe flow (Re=1400) and the residuls of all simulation are less then 1e-3. When I have a mesh with more cells the result seems to be of a turbulent flow. Thanks in advance. John |
February 18, 2005, 03:10 |
Re: Laminar pipe flow
please don't go for the residuals because they often create confusion. Better you check the results with analytical solutions. Here is one link of cornell university. You will find the "laminar flow in pipe". go through it and i hope u will be happy. http://instruct1.cit.cornell.edu/courses/fluent/ bye
February 18, 2005, 13:37 |
February 18, 2005, 13:42 |
Thanks Randheer but what I'd like to know is why my results are getting worse compared whit analytical whit a mesh whit more cells. I think it should be the oposite. Thanks.
February 22, 2005, 02:38 |
Have u attached boundary layer on the inner surface of the pipe?. If not then please try it. I think this should give u more accurate solution than making grids finer.
December 5, 2014, 05:00 |
#6 | |
Arta Lotfi
could you mail this file for me please? , i cant open it thanks |
February 24, 2005, 08:14 |
how will be affect cavitation for this flow
and also difference between laminar and turbulent flow |
Boundary conditions of laminar flow in pipe | alireza.glz | OpenFOAM | 4 | May 27, 2019 05:03 |
Using a turbulent model when the flow is entirely laminar. | mwhyte | FLUENT | 1 | June 7, 2012 10:35 |
gravitational acceleration in laminar pipe flow | atmcfd | ANSYS | 0 | January 4, 2010 22:19 |
Flow laminar and stationary of water in a pipe | manuel | OpenFOAM Running, Solving & CFD | 6 | March 24, 2007 18:23 |
First steps - laminar flow in a pipe | Maria | Phoenics | 8 | November 27, 2001 11:26 |
