Velocity inlet problem
Old   February 18, 2005, 04:38
Default Velocity inlet problem
KKLAU
To fluent experts,
If i set the velocity inlet value to 0 m/s in xy direction, does it same with the wall boundary condition? I tried to both cases and found that they are different? Can you anyone tell me why ???
Thank you.
KKLAU
Old   February 18, 2005, 05:29
Default Re: Velocity inlet problem
Luca
it's interesting...some time ago I tried your same case. What kind of solver are you using? segregated or coupled. Try the segregated! it should work. What are you trying to simulate? Pay a lot of attention with this trick... Luca
Old   February 18, 2005, 06:04
Andrew Garrard
Hmmm, this is interesting. What exactly does a wall boundary condition impose on the velocity field. As is my understanding it sets the x, z (and if 3d z) velocity to zero. Are you setting all two (or three in 3d) components to zero? If so, what values of flow are at the "wall/velocity inlet" when you plot contours of x, y and z velocity, and how do they differ from just using a regular wall?
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 05:45
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 09:02
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
