Turbulence model for backwards facing step
Old   February 26, 2005, 16:56
Default Turbulence model for backwards facing step
Riaan
Hello everyone,
I am currently investigating flow separation and re-attachment over a rearwards facing step.
To date, I have been using the S-A turbulence model, because of computational efficiency, and in order to get a 1st order approximation of what I am looking for.
My current task is to improve the turbulence model selection. I considered the K-epsilon model, but literature states that it does not accurately simulate the separated region with the reverse flow.
Any suggestions? If I go to a Reynolds Averaged or a Large Eddy simulation, I doubt my computer could handle it !
Old   February 26, 2005, 17:29
Default Re: Turbulence model for backwards facing step
Riaan
Actually guys, thoughts on K-Epsilon with Non-Equilibrium wall functions would be appreciated.
Old   February 27, 2005, 04:27
reis
you may try v2f model. it can handle this problem better than ke and sa but requires some more comptutational resource than both of them...
Old   February 27, 2005, 12:02
Riaan
V2F - 4 equation, LES and RANS combined, right?
Am I correct in assuming it will take double the time of the 2-equation models, or will it take more?
Old   February 27, 2005, 14:58
reis
it is based on rans. accurate tool for seperated flows and will cost slightly larger than a simple k-e model
you can find detailed info and test results and comparisons with k-e at:
http://www.turbulentflow.com/
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 21:45
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 08:53
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
