Wall function
Old   March 17, 2005, 12:04
Default Wall function
Y
hi I am simulating flow behind a bluff body. Not I know that if I want to use the wall function. the y+ plus values should not be less than 11 and greater than 60. How can I make delta x of the first node to the value which I require and use the structure grid i.e delta x in other cels are equal and less than delta x in the first cell.
Y
Old   March 17, 2005, 13:33
Default Re: Wall function
galeazzo
You can try the Viscous Grid Spacing Calculator. You can find the link to it in the CFD-online web page.
http://www.cfd-online.com/Resources/calcs.html
Galeazzo
Old   March 18, 2005, 02:21
Y
I know the spacing how can I fix this spacing for the first node and use other spacing for grids from second node to last node. Y
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 07:22
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
