February 28, 2005, 12:01 |
GAMBIT problems and SUBTRACT command
Hello guys,
GAMBIT : Well, can anyone tell me why my initial edges, created in order to create surfaces, have disapeared after i performed a SUBTRACT command ? The GAMBIT prgm created new edges by his own after this operation ... and this misstate my journal file (*.jou) i created !? Anyone can give me some advices on this one ? Thanks folks, Matt |
March 1, 2005, 09:51 |
Re: GAMBIT problems and SUBTRACT command
It's true, Gambit forgets your original edges and creates new ones in their place, on the subtracted part. The item it's subtracted from does not have this problem. What a hassle.
What problem is this causing? If you need to be able to refer to these edges by name, one workaround is to use loc2ent(,,,) which returns the name of an item based on what item type and the XYZ coordinates of a point on the item. This sort of does what otherwise requires clicking a mouse on it. |
March 2, 2005, 07:41 |
thanks for your idea but there are too many eadges to refer too, i think i am going to rethink my drawing,
cheers Matt |
March 1, 2005, 16:23 |
You need to ad parameter 'Retain', I think?
March 2, 2005, 07:42 |
Thanks for your help, but there is no such command as 'retain'. There is keeptarget and keeptool command but they don't seem to work out my problem ..
cheers Matt |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Help needed with Cornell's Gambit airfoil tutorial | Arti | ANSYS Meshing & Geometry | 3 | May 30, 2009 03:40 |
problems with STEP file | ertan | FLUENT | 0 | August 1, 2008 17:51 |
meshing geometry in gambit | soundar | FLUENT | 1 | January 7, 2005 02:59 |
