heat transfer not working well
Old   March 1, 2005, 01:22
Default heat transfer not working well
ocy
Hi all,
I have a vertical duct where there is air inside.
The bottom walls of the duct heat up the air as it flows in through the inlet.
When i remove the insulation of the wall, only a small region near the wall shows temp decrease. The main bulk of the air still maintains a high temp.
Is this normal? or have i done something wrong? Pls help. Thanks in advance
Old   March 2, 2005, 11:42
Default Re: heat transfer not working well
Evan Rosenbaum
Check your flow regime. If you have laminar flow, you would expect a near-wall effect only.
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
