Convergence.
Old   February 21, 2005, 02:50
Default Convergence.
Muhamad
hello,
can someone pls tell me what is wrong when the solution does not converge?
I have tried so many times and it just does not converge.
Muhamad.
Old   February 21, 2005, 03:23
Default Re: Convergence.
Naresh Khumar
hello friend,it's my view is the mesh will be the problem.
please delete the mesh and again the mesh
Old   February 21, 2005, 21:57
Venugopal
You have tell about your problem and the way you have given the gird.
Venu Gopal
Old   March 1, 2005, 09:53
white
Convergence difficulty normally caused by: 1) meshing quality
- remesh your model with good quality grid 2) under-relaxation factor value
- reduce the value of under-relation factor
Try this!
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
