March 7, 2005, 03:23 |
? Meshing volum in GAMBIT
Dear fellows,
My volume is representing a parellel channel for fuel cell. In order for me not to have sub-mapping problems during the meshing generation, i had to define my volume into many different lines. Now, for creating the surfaces, to generate the volume afterwards, i din't make use of all the lines. _ _ _ |_|_|_| = all the lines _ _ _ |_ _ _| = the surface; and from this surface creation of the volume My question is to know, if those lines (the vertical once), which are still yellow (in GAMBIT) and not included in the volume (green), will cause any troubles during FLUENT calculations ? Thank, hope you can help me ... Matt |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
Meshing Aircraft with Gambit | Ed | FLUENT | 5 | November 9, 2004 05:04 |
