stones 0.055 in porous media
Old   March 18, 2005, 05:37
Default stones 0.055 in porous media
mihai
I have a big cylinder full with CaCO3 stones of 0.055 m diameter how can i say that to mr. fluent?
Thanks a lot!
Old   March 18, 2005, 09:29
Default Re: stones 0.055 in porous media
Amir
You need to come up with proper values for C1 and C2 when you use porous media model in FLUENT. I would check out FLUENT manual ,chapter 6, to see what's their hint on that or use following reference to calculate proper Ergun coefficients
Kaviany, M., 1991, Principles of Heat Transfer in Porous Media, Springer-Verlag, New York.
Old   March 18, 2005, 10:03
mihai
thank you very much! i ll try
Old   March 19, 2005, 11:20
Bak_Flow
a well tested correlation of the loss coeficients based on the open porosity and diameter of packed spheres: is called the Ergun equation. You can find it in many texts like "Unit operations of Chemical Engineering" McCabe, Smith and Harriot.
Good Luck..........Bak_Flow
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
