How to define Cp using UDF?
Old   January 27, 2005, 23:47
Default How to define Cp using UDF?
Feng
I am using FLUENT 6.1 to model solidification process. Since FLUENT can not define thermal-physical properties seperately for solid/liquid, I have to use UDF to realize the task. However, there is no "user defined" option for Cp. I don't know why and want to know how to define Cp for solid and liquid seperately. Any suggestions will be appreciated very much!
Old   January 28, 2005, 13:21
Default Re: How to define Cp using UDF?
lily
Try to use DEFINE_PROPERTY and define Cp. Once complied, link the defined Cp to the material property.
Old   January 28, 2005, 16:09
Feng
Thanks for your reply. I was trying to do so. I can do this for density and conductivity, but this doesn't work for Cp, since there is no "user defined" option in the dropping list for Cp. I don't really know why there is no "user defined" option for Cp. Any further advice will be appreciated!
Old   January 31, 2005, 02:09
2L
According to Fluent user's guide, "UDFs cannot be used to define specific heat properties; specific heat data can only be accessed and not modified in FLUENT." So I think you should use the mixture model or something using species (one for liquid phase and one for solid phase). Hope it will help you.
Old   February 2, 2005, 01:42
FJ
You have to customize the real gas model. Otherwise,you can't do that even via UDF in usual way.
Thanks,
Old   November 15, 2012, 16:36
Default This might be too late i guess
Abhijeet Shrawage
ashrawage is on a distinguished road
but this is how you have to define specific heat using a UDF
DEFINE_SPECIFIC_HEAT(Cp, c, t)
hope it helps either you or someone else who stumbles on to this thread.
ashrawage is offline   Reply With Quote
How to use UDF to define a moving wall lingo FLUENT 9 August 19, 2014 09:14
Define profile inlet_temperature in UDF mohammadkm Fluent UDF and Scheme Programming 19 December 24, 2013 22:42
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Help: using udf to define direction Bo FLUENT 1 July 16, 2008 06:47
UDF to define source term at every grid point Ralf Schmidt FLUENT 0 September 21, 2006 11:32
