X-Y Plot along an edge
Old   March 23, 2005, 17:08
Default X-Y Plot along an edge
Riaan
Hi guys,
How do I do an X-Y plot of data along a given edge of a 3D model (in my case a delta wing).
When I create a plane, I get a whole set of edges, and I cannot use the line command because my model has all sorts of funky angles.
Please advise, there must be a way to do something this simple!
Old   March 24, 2005, 06:56
Default Re: X-Y Plot along an edge
Jason
I'm having the same issue right now... one way that works well is using iso-surfaces. You can create a surface of constant grid functions (say constant x-coordinate, or angular coordinates, etc..) and select the surface you want it to interesct with under "from surface". For example, if you wanted a curve on your wing at x=1m, you would create an iso-surface of constant x-coordinate, and input 1m as the iso-value... then select your wing under "from surface".
The problem I'm currently having is that my surface can't be defined under the limited options under iso-surface... if you learn of any other way of doing this, I would apppreciate any information.
Thanks, and goodluck, Jason
Old   March 24, 2005, 19:11
Riaan
Thanks, it works well for my case!
how to plot attack angle along with impeller span direction at leading edge wildli FLUENT 0 August 31, 2010 14:47
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
