March 30, 2005, 20:23 |
Easy GAMBIT question
Hi I have a beginner-level questions about GAMBIT:
When creating two volumes adjacent to each other, do they need to share a common face? I see that I can make two (or more) faces at the same location, which can be used to construct different volumes. I would not like to boolean add these volumes together because that makes me lose grid information on some of the edges. Which way should I go to make sure that the face is a fluid-fluid interface -- one face or two? |
March 31, 2005, 02:09 |
Re: Easy GAMBIT question
Hi!
If two volumes share one common face you can forget about it...fluent(gambit) automatically sets it as a fluid-fluid interface. If you have 2 faces (each designated to one volume) in the same position (for example if you create 2 cubes on besides another) fluent(gambit) will treat it as an outside wall...that means that yoou have to specify them (both!) as intrefaces... hope it helps MATEUS |
Gambit question | HP | FLUENT | 8 | March 4, 2005 08:32 |
Question on Gambit. | Sham | FLUENT | 2 | February 15, 2005 20:07 |
Easy question | Confused | Main CFD Forum | 4 | May 22, 2004 02:14 |
GAMBIT QUESTION | stephen davis | FLUENT | 3 | March 11, 2002 10:52 |
GAMBIT Question | Eric | FLUENT | 2 | February 28, 2002 22:24 |
