heat transfer coefficient ?????
Old   March 23, 2005, 16:15
Default heat transfer coefficient ?????
Babu
Hi all:
When I was plotting htc's (wall heat transfer coeffecient's) in Fluent I see strange numbers (-ve values in 1000's when flow is incompressible having mach number < 0.1). I checked fluid and wall temepratues, it was showing correct values. I used references tables to plug values from there. I suspect something went wrong somewhere. Can anybody help me in this regards.
thanks in advance (very urgent to me) Babu
Old   March 25, 2005, 05:44
Default Re: heat transfer coefficient ?????
Alex
Fluent calculates h through the reference temperature in "report" -> "reference values". You should first calculate mass-average temperature in the section where you r interested in h calc-s. Then, plug it into the reference value. Hope it helps.
Old   March 27, 2005, 03:47
dpshaka
fluent is not a very smart animal.
i often let fluent caulate heat flux first ,then the temperature difference ,and area . then i get the value of h
Old   April 1, 2005, 02:42
Alex
dpshaka if you have a heat flux, what do you need the area for?
Old   April 3, 2005, 04:27
dpshaka
i am sorry ,i give a wrong concept
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
