First use of Gambit
Old   April 19, 2005, 15:02
Default First use of Gambit
indd
I'm using for the first time gambit but i still don't know how to proceed in order to obtain the user interface.
It would be very nice if someone can explain to me how to do it.
Thanx in advance
Old   April 19, 2005, 16:41
Default Re: First use of Gambit
easycad
Have u installed x-server? If yes then specify what OS u are using. For windows ude command line: gambit -id xxx where xxx is name for your case.
Old   April 19, 2005, 19:45
pUl|
http://www.fluent.com/support/instal...tartgambit.htm
Old   April 20, 2005, 04:18
indd
Thanx for ur response. I'm working under windows and its running
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 01:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
