compiling error
Old   May 2, 2005, 01:31
Default compiling error
baskar
sir i am having problem in compiling udf (compiled) in running fluent 6.1 i have browsed my source file then loaded i got the following errors
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2d")0 (system "copy C:\Fluent.Inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2d")()
Done.
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Old   May 3, 2005, 02:53
Default Re: compiling error
Volker Pawlik
Put the UDF-source file into the same directory as your case. Normally a message gives you that hint (it is so with fluent 6.2)
Old   May 4, 2005, 11:49
kamarul
If you are using Linux OS, start up your fluent software in the directory where you put your UDF file.
Start with fresh compilation, ie delete the previous libudf.
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
