UDF - adjusting boundary conditions
Old   May 8, 2005, 07:30
Default UDF - adjusting boundary conditions
olivort
I want to adjust the velocity inlet. Did somebody know how to do?
I ve already tried this:
DEFINE_ADJUST(adjust_fcn, d) {
face_t f2;
t2 = Lookup_Thread(d,4);
begin_f_loop(f2, t2)
F_CENTROID(x,f2,t2);
y = x[1];
F_PROFILE(f2, t2, 4) = -Qair/(13.8*rho*aire);
} end_f_loop(f2, t2) }
but fluent tells me an access_violation error
I also tried with
face_t f2;
F_U(f2,t2) = Qair/(13.8*rho*aire);
printf("vitesse d'une face: %g\n", F_U(5,t2)); /* give the right answer! }
but the velocity inlet doesn't update (i have put it in the function hooks).
Does anyone have a solution to the problem of adjusting boundary conditions on each computing step?
Old   May 9, 2005, 02:48
Default Re: UDF - adjusting boundary conditions
Luca
Why don't you declare Thread *t2? Luca
Old   May 9, 2005, 03:44
olivort
I don't wrote all the code. But the only problem is to redefine the boundary condition at each computing step.
Old   May 9, 2005, 03:54
Luca
Use the define_profile function. please read the UDF manual. Luca
Old   May 9, 2005, 05:00
pratap
what is this UDF manual
Old   May 10, 2005, 14:26
olivort
Yes but my problem is not to define at the beginning a boundary condition (that's with define_profile) but to adjust it each computing step (with define_adjust). I don't know how to modify this boundary condition without having a access_violation error.
Old   May 10, 2005, 14:39
Luca
define_profile can be used in time dependency too. You just have to use the time macro. You have to hook correctly youe define_profile in the bc where avaiable. Otherwise you can use a define_adjust. You should checkyou have written a correct UDF, not only using correctly Clanguage but that your UDF has a logical sense. Luca
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
read boundary conditions with udf Bernhardt FLUENT 0 May 31, 2007 09:46
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
