May 9, 2005, 04:09 |
ERROR!!
I keep getting the error: TEMPERTAURE LIMITED TO 1 When does this occur and why??
May 9, 2005, 04:28 |
Re: ERROR!!
temperature limited to 1k means fluent has calculated a negative kelvin temperature. this makes no sense an therefore the lower temperature limit is used instead of the calculated value. you can set the limit for temperature, pressure etc. in solve->sontrol->limits. why does it occur? its hard to say. i observed this message sometimes during combustion modeling with an negative heat flux as wall bc.
rom |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
