Gravity flow
Old   May 22, 2005, 01:19
Default Gravity flow
Sadhna
I am a new user in Fluent
I have a porous cylinder through which a fluid trickles down by gravity (the inlet velocity is known)
Both the flow inlet and outlet are open to the atmosphere (i.e. pressure here should be 1 atm). The sides of the cylinder are walls.
I declare a velocity inlet for the flow inlet, porous fluid zone for the cylinder and pressure outlet for the outlet.After simulation,the pressure countours dont show 1 atm static pressure at the inlet.But at the exit you see 1 atm (because of the pressure-outlet B.C., I guess)
How can I specify the inlet velocity and pressure both of them at the flow inlet? can this be done? Also,How should I ensure flow is by gravity (Will switching on the Gravity option in Operating Parameters panel suffice?)
Please help,
Sadhna
Old   May 23, 2005, 08:20
Default Re: Gravity flow
Honza
Hi, all the pressures you specify are RELATIVE pressures with respet to 'operating pressure' in Oper. cond. panel (default is 1 atm). Set 0 Pa at outlet. To display absolute press. scroll down in Pressures ... subpanel to Absolute pressure. You cant specify pressure at both inlet & outlet AND velocity - it would be overspecified. Gravity option on is sufficient. Regards Honza
Old   May 23, 2005, 11:03
sadhna
Hi Honza,
Thanks for your kind attention
I have done the following
inlet-velocity inlet (I specified a given velocity)
outlet-pressure outlet - 0 Pa (gauge pressure)
Plz note that the inlet is at a vertical height of 0.6m above the outlet and the coordinates of the origin are at the inlet (so that y coordinate is negative into the geometry)
For the cylindrical region containing porous media, I enabled the Porous model and supplied the necessary resistance coefficients
In operating panel, I switched on the gravity option and specified operating pressure as 101325 Pa (1 atm)
And now for the surprise!!!
In the absolute pressure contours I see that the pressure at the outlet is 1 atm (as expected) but the pressure at the inlet is more!!! (pressure should increase with depth, am I right???)
What do you think has gone wrong in my case?
waiting for suggestions,
Sadhna
Old   May 24, 2005, 09:00
Honza
Hi, the hydrostatic pressure is not displayed. What you can see is pressure drop caused by flow resistance. Honza
Old   May 24, 2005, 10:19
Sadhna
Hi Honza,
Can you explain in detail what you mean?
Do you mean to say that pressure at the top is more than that at the bottom due to flow resistance present in between the two?
Is this pressure calculated by something like Hagen Poisuelle equation (that gives pressure drop for packed beds such as the one in my case)?
Please elaborate,
Thank you,
Sadhna
Old   May 30, 2005, 05:06
Rajesh G
I agree with Honsa and what you can do is to specify the operating pressure as zero (not 1 atm!)along with the zero gauge pressure condition at the outlet.
Rajesh
Old   May 30, 2005, 08:15
Sadhna
Hi Rajesh,
What do you mean by setting the operating pressure as 0 atm (btw,is this guage pressure???).How does that fit in the context?Did Honza mean that?
Regards, Sadhna
Old   May 30, 2005, 10:19
Rajesh G
If you have given the operating pressure as 1 atm that means that you have given the absolute pressure as 2atm as the operating pressure generally will be gauge pressure . If you are giving the operating pressure as 0, your absolute pressure will be 1 atm , i.e the atmospheric pressure. That's what Honsa also told that you might've gone wrong with the relative pressure concept used in the Fluent
Old   May 30, 2005, 10:48
Rajesh G
What I mean to say is normally if you want fluent to start the calculations from the initial conditions, i.e especially in your case, its atmospheric pressure at both inlet and outlet, the operating pressure should be atmospheric, that's, the gauge pressure is zero (hope u know pressure gauges read zero when the presure measured is atmospheric.... as you are wondering whether there can be zero gauge pressure!). So what I think, the "culprit" in your case, as you are also thinking, is the inlet pressure, being high because you have given the operating pressure as 1 atm (gauge) that means 1atm above atmospheric.
Old   May 30, 2005, 12:41
Balaji
hi,
The pressure at the outlet is atm as you have specified.But there may(should be because you are using porous media) be pressure drop inside the domain it will include frictional,accelerational and gravitational.So you calculate the all the pressuredrops in the domain and add this pressure with atm pressure and check whether this is the pressure which has been shown by Fluent.Since you have set the outlet pressure the inlet pressure will adjust according to the pressure drop.
Inlet pressure should be more than outlet pressure.If there is no pressure difference how the flow take place.
I feel I am right.You can check with this.
bye
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
VOF gravity flow BC Alexander Ladino CFX 1 March 28, 2007 14:45
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Gravity influence of flow :Urgent Suresh Balasubramanian FLUENT 3 August 6, 2003 11:06
