Wind turbine simulation help
Old   April 15, 2009, 15:44
Default Wind turbine simulation help
kirit
kirit_GSU is on a distinguished road
I am trying to simulate 2D savonius rotor wind turbine. but i have done every thing good so far expect the post processing one.
I am trying to calculate the Drag coefficient and Lift coefficient of my work. The way which i am using right now. Report > Forces> then i am going to x and y direction forces. Then converting the the forces in to tangential force and normal force using those two Equation :
Fn= Fx*SinA+Fy*CosA
Ft=-(Fx*CosA-Fy*SinA)
Here is A is 0 for balde1, 120 for blade2, 240 for blade 3 .
After that i am using the formula
Cd=Fd/(1/2*p*U*U*A)
Cl=Fl/(1/2*p*U*U*A)
to calculate drag and lift.
But i am not getting the value which i am suppose to get for this work. Am i going to the right way ??
I have attached jou file i am not sure you will be able to see that please let me know. i cant upload the cas file as the size is more than 97 kB.
thanks in advance
Kirit
kirit_GSU is offline   Reply With Quote
Old   April 16, 2009, 10:53
kirit
please see the cas file at
http://rcpt.yousendit.com/676477626/...9dd604c4aeb713
with thanks.
Old   May 18, 2009, 11:10
Thanh Nha Nguyen
sime is on a distinguished road
Hi kirit!
I doing the same problem to u. But i don't know how to Apply the inlet and outlet. How can we apply the angular velocity of rotor what the unknown of turbine problem?
sime is offline   Reply With Quote
Old   June 23, 2009, 06:49
Default wind turbine rotor
sivaramakrishnaiah
sivarama1 is on a distinguished road
Send a message via MSN to sivarama1 Send a message via Yahoo to sivarama1 Send a message via Skype™ to sivarama1
hi all,
i am also doing same problam
please send me your case file and gambit file,i will check it,
sivaramakrihnaiah
sivarama1 is offline   Reply With Quote
Old   June 23, 2009, 10:09
kirit
I cant upload file coz its big than they permit. if you give me your mail address i can send it to you
thanks
Kirit
Old   June 24, 2009, 06:47
Default windturbine simulation help
sivaramakrishnaiah
Hi,how are you,
Thankyou very much,
My mail ID:siva@green-line.com,malayathisiva@gmail.com,
sivaramakrishnaiah@live.com
sivaramakrihnaiah
Old   April 22, 2010, 22:45
yashwant
saini.yashwant is on a distinguished road
Originally Posted by sivarama1 View Post
hi all,
sir i am student of M.tech at NIT surat. i am doing numerical simulation of wind turbine by fluent. so i am facing some problems with defining the boundary conditions. so wl u please help me regarding boundary conditions.sir i have modeled wind turbine in gambit and meshed it with two domain interior domain with .5d same as wind radius. and another one is off bigger domain of 4d in diameter. and 3d in front and 5d in back. i have defined the interface in between the surfaces of interior and outer domain. by giving the condition of rotor stationary and the near by domain air is rotating i am getting the axial velocity at the rotor plane more than inlet velocity. is this correct or not. and please help me out how to calculate the power output and coefficient of power.
thanks
saini.yashwant is offline   Reply With Quote
Old   April 22, 2010, 22:48
yashwant
Hi,how are you,
Thankyou very much,
thanks
Old   April 23, 2010, 00:15
Default wind turbine design
sivaramakrishnaiah
Hi
This is my DESIGN Calculations,but i was done in CFX,i know in little bit in fluent and gambit
http://www.4shared.com/document/Vnjp...dturbine3.html
http://www.4shared.com/document/KaBz..._TURBINE1.html
sivaramakrihnaiah
Old   April 23, 2010, 00:25
yashwant
sir i hav calculated all this by developing the code for BEMT meathod. but i require the guidence regarding CFD analysis either in fluent or cfx. how to calculate all thins with these softwares
Old   April 23, 2010, 04:24
  #11
sivaramakrishnaiah
Hi
ok, very long back i was done simulation in CFX-11
Boundary conditions:
Inlet:Stagination Temperature and Velocity(sunsonic)
Outlet: static pressure(subsonic)
K&e model,boundary layer 2mm
sivaramakrihnaiah
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Wind Turbine Dynamic Simulation Michele FLUENT 2 June 10, 2009 07:14
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
Wind turbine simulation Saturn Main CFD Forum 1 June 12, 2006 03:57
CFX-TASCflow, wind turbine simulation Sac CFX 0 June 7, 2004 03:33
