k-e turbulence
Old   June 2, 2005, 17:43
Default k-e turbulence
hung
Hi everyone!
Now I'm modeling a turbulence flow over the spheroid by Fluent, and I used K-epsilon model. But my result ( Cf, Cp....) are quite difference to the results in the paper.
I used the K-epsilon, but I'm not sure about the coefficients in this model, for example k, epsilon....
Somebody can recommand to me, how to simulate it to get a better result. Thanks a lot!
pah
Old   June 2, 2005, 20:02
Default Re: k-e turbulence
zxaar
read the discussion "Which do you prefer? 6.1 or6.2?" on this page, there what ever i have said is applicable to the case you are talking about.
Old   June 3, 2005, 00:09
hung
Thanks for your reply!
I'm doing with the Prolate spheroid 6:1 and it has angle of attach 10, 20 deg at Re=4.2*1e6. And I did with k=0.1, epsilon=0.1. But the result so bad.
Somebody, Plz recommand to me the way to simulate it. Thanks one more!
PAH
Old   June 3, 2005, 01:14
zxaar
did you read the discussion i suggested to read,
Old   June 3, 2005, 01:46
hung
Hi zxaar!
I did, that's great and detail guiding. But my problem now is Turbulence models only. Because I want to complete turbulence model at the Steaty state case first, if it's true then I go to unsteady case.
Therefore, I'm considering the Tur coefficients. Could you recommand some ideas about it to me!
Thanks a lot!
PAH
Old   June 3, 2005, 02:25
zxaar
see if you have to stik to steady state calculations of k-e type, the best results you get with k-e realisable, and if u can have yplus near to 1, use enhanced wall functions, but with k-e type models you will need prism mesh near to walls of your body. and using yplus near to 1 is your best bet.
i suppose RSM should also give good results but i haven't tried it yet. note using prism near to walls gives best pressure coefficient predictions.
Old   June 3, 2005, 02:46
hung
Thanks for your recommand!
I use the k-e model and my grid on the wall is hex, because the hybrid grid is used in my model in some blocks.
And then, at the Models is set up with k-e realisable. But in the Inlet BC, we need to set up K, epsilon. In here, I'm trouble. I just set them as I mentioned.
Thanks !
PAH
Old   June 3, 2005, 02:52
zxaar
use intensity and lengh scale instead, read what manual has to say about it, in the boundary conditions part, then judge what you want to set,
Old   June 3, 2005, 04:38
hung
I want to set the dimensionless model of flow over the spheroid, and then I use the Velocity inler is U=1 with the long axe a=1.
Do you have some ideas about dimensionless in Fluent?
Thanks a lot, Zxaaz!
PAH
Old   June 3, 2005, 05:34
zxaar
nope i never tried that
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
