y+
Old   June 22, 2005, 11:32
Default y+
anto
Hi guys! I'm running a case with the following setting: 2D stationary k-epsilon realizable with wall function non equilibrium, second order accuracy and double precision. I have y+<30 in an small area on the upwind face. I would like to know if this problem can cause local or global effects ? Thinking about correcting the y+ just in this area, do you suggest meshing or y+ adaption? Thanks in advance for your help! Anto
Old   June 22, 2005, 17:20
Default Re: y+
galeazzo
You should not have problems if your y+ values are above 11. Check the guidelines in the FLUENT manual...
Old   June 23, 2005, 12:12
Default Re: y+
anto
thanks for the advice! However my y+ value < 11... I'm looking for a way to change the mesh, what do you think about y+ adaption?
Anto
Old   June 27, 2005, 04:52
Default Re: y+
Adel
hallo, how about Boundary Adaoption (2-4 cells all the walls). Best regards
