Bubble columm - BC
Old   June 10, 2005, 09:56
Default Bubble columm - BC
Sic
Hi everyone. My problem is a bubble columm (water-air). There is an inlet of air in the bottom e i would like that just this air get out in the top. My question is: Who can i put a boudary condition that just the air massflow out and the water not?
Thanks
Old   June 10, 2005, 10:07
Default Re: Bubble columm - BC
aPpA
One way of doing this is, extend the height of the bubble column over the liquid height and patch it with unit vof of air. This will make the water to stay in the system and not go thru the pressure outlet/outflow boundary condition for the outlet. Better free surface conditions such as "Degassing boundary condition" are available in FLUENT as UDF's
Old   June 10, 2005, 10:13
Sic
And how can i use the UDF? Do you have some example of this kind of boundary condition? Degassing boundary?
Old   June 10, 2005, 10:21
aPpA
I never tried to use the degassing boundary condition UDF by myself, but u can get it from the FLUENT UDF archive examples. The procedure how to use it is explained clearly in the UDF. Goodluck..!
Old   June 10, 2005, 10:23
Sic
thank you very much!!!!
bubble rising problem swamysrikanth ANSYS Meshing & Geometry 3 May 31, 2016 11:09
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Separation bubble, hypersonic compression corner ben akih CFX 3 December 10, 2006 16:33
gas hold up in bubble Shelly Main CFD Forum 0 November 13, 2006 00:28
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
