LES help
Old   June 15, 2005, 10:24
Default LES help
Alex
Hi. I'm trying to LES a concentric annulus flow using periodic BC. Actually, I'm talking about two pairs of periodic BC faces (don't want to mesh the whole 360). One in the flow direction (X)-parallel to the axis and the other on the sides of say 30 degrees sector which should be at 30 one to the other. Is there going to be a problem in Fluent? I.e. will it be enough to define flow in X direction in the periodic BC and it will be equal velocities etc. at the second pair of faces? Thank you.
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 13:21
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
