3-d grid generation
Old   June 16, 2005, 06:49
Default 3-d grid generation
Madhukar Rapaka
I am about to start my project in Fluent. I have to simulate the flow thru a 3 dimensional Heat exchanger in fluent. For this i have to generate a 3-d grid for the heat exchanger in Gambit. As i am new to these sofwares... i request you to tell me the tips and the things to take care of in generating a 3-d grid. it will be helpful for me, if anyone give me some solved examples files of 3-d geometries.
thank you
Old   June 18, 2005, 06:19
Default Re: 3-d grid generation
Mehdi Ghoddosy
Dear Madhukar: I believe you had better to try two dimesional modeling first. Use down-top approach.Means that you have to creat vertices first and then edges and faces. Mesh(Grade) edges first. By grading edges you can create structures quad. meshes in relatively simple but a little more time consuming. As possible, try to use structured hexahedral mesh using map meshing scheme. They are best for accuracy and convergence.
Regards
need help for generation grid aya FLUENT 11 March 4, 2008 14:46
3D Hyperbolic Grid Generation - Help Requested... Marcus Lobbia Main CFD Forum 2 November 9, 2003 05:53
Help Re. Grid Generation Patel Amit R. FLUENT 1 February 28, 2003 21:27
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
