UDF
Old   June 15, 2005, 21:54
Default UDF
Moose
Hey,
I get the following error;
Error: open_udf_library: s_wsle
when trying to run a UDF linked to a FORTRAN subroutine. ALthough linking is without errors the above error manifests itself when I try to load the UDF in Fluent. (Btw I use Linux and I compile and link in text mode)
Seems that I have some kind of undefined reference to the runtime library s_wsle. I can easily circumvent the problem by removing for instance all 'write' statements in the FORTRAN code, but since they are kind of needed I'd rather solve the problem.
Does anyone have a clue?
Thanks.
Old   June 21, 2005, 01:33
Default Re: UDF
Joey
Once I met the problem. When I loaded the UDF in the 6.1 edition, which had been compiled with the editon 6.0, this message appears. Btw I use Fluent in the win2000. Hope it helps!
Joey
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
