boundary condition at nozzle exit
Old   June 30, 2005, 05:18
Default boundary condition at nozzle exit
Akbar
What should be the boundary condition used for nozzle outlet surface? Pressure far field or presure outlet, both are resulting different results. Exit of nozzle is at ambient condition.
Same case file is not going to converge for diffirent inlet pressure ( low pressure values ) while other conditions are same.
Anyone can help!
Old   June 30, 2005, 05:46
Default Re: boundary condition at nozzle exit
Luca
You should use pressure-outlet. Pressure-far-field should be used for aerospace external flows to set the flow-conditions. Luca
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 22:55
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 06:40
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
