June 30, 2005, 11:55 |
Node spacing
Hello there,
I recently posted a message reagrding node spacing Vs quality, to which i received a very helpful response. As an additional question, I was wondering if anyone is able explain the following: I am modelling a small part with some dimesions 0.1mm. When i create the grid in GAMBIT, the nodes seem to be spaced further apart than what my minimal dimensions are in the geometry.... So, does that mean that any geometry smaller than the node spacing would not be accuratly simulated? Any suggestions or help woule be greatly appreciated, Many thanks, Gary. |
July 1, 2005, 11:08 |
Re: Node spacing
Gary,
Under the "mesh edges" tab there is an option that says "interval count". Try using that option instead of "interval size" and specify how many nodes you want in that small edge, then keep meshing the rest of the edges but maintain uniformity, then mesh faces and then volume. good luck! AJG |
July 1, 2005, 11:25 |
Re: Node spacing
ok thanks. i'll give it a try!
Gridgen node spacing | Vincent | Pointwise & Gridgen | 4 | August 7, 2016 17:33 |
gambit edge node spacing | sayeem | FLUENT | 2 | December 13, 2010 05:12 |
License server not visible from master node | Charles | FLUENT | 0 | October 30, 2007 17:48 |
Node Spacing and number of nodes | hagupta | CFX | 1 | June 12, 2006 06:45 |
small node spacing | Gary Holland | FLUENT | 13 | June 10, 2005 10:06 |
