July 12, 2005, 09:28 |
Time dependant BC's
I want to look at transient flow in a simple rectangle chamber. The flow will be driven from an inlet and will leave the chamber via a single outlet.
I would like to change the mass flow rate entering the chamber and set it as a function of time. For now lets say 0.1kg/s for the first 10 secs and then 0.2 kg/s for the next 50 secs. Any pointers on how to set up this time dependant BC's. Do I need to look at UDF's? |
July 12, 2005, 11:39 |
Re: Time dependant BC's
yes,you can use UDF to specify the BC.
July 12, 2005, 12:09 |
If it is a step change like you describe, just run the transient for ten seconds, change the BC, and pick up the transient where you left off for the remaining 50 seconds.
July 12, 2005, 16:01 |
Thank you both for your responding. The simple case I described was given to help give me an insight into the process of setting up and running UDF's. And so that's why I didn't just run, change and then re-run.
I will do more trialling and then come back with questions, as/if they arise. |
July 12, 2005, 16:40 |
Hi, this is an example from my UDF to change the inlet temperature as a function of time. You can do the same thing as this.
/* Define boundary profiles */ DEFINE_PROFILE(heating_rate,t,i) { float rate, T; real factor; real flow_time = RP_Get_Real("flow-time"); face_t f; rate = 0.0125; /* deg per sec */ factor = 1000.; begin_f_loop(f,t) { if (flow_time > 4) F_PROFILE(f,t,i) = 443; else if (flow_time > 3.3) F_PROFILE(f,t,i) = 420; else if (flow_time > 1) F_PROFILE(f,t,i) = 400; else if (flow_time >0.1) F_PROFILE(f,t,i) = 393; else F_PROFILE(f,t,i) = 373; } end_f_loop(f,t) } |
July 13, 2005, 04:17 |
Thanks Quak,
A few 'follow-up' questions, if I may, What is the role the variables 'factor' and 'rate' in your UDF? You set 'T' to be a real. since 'C' is case sensitive what also is this variable used for. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Time dependant velocity profile | en51nm | STAR-CCM+ | 1 | July 15, 2009 07:20 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
