Radiator
Old   July 15, 2005, 06:50
Default Radiator
Renato Sousa
Hello, I'm trying to simulate the flow inside a room using those wall radiators as a heating system. The problem is that I don't want to mesh the detailed geometry of the radiator since it has sheets of about 1mm. I'm trying to simulate it as a rectangular prism, but the problem is how to have the same surface temperature and heating power as the real case, since the area is not the same. If I input the temperature, the heating power is subdimensioned, if I impose the power, the temperature will be to high.
I tried to solve it as a porous media, but then there is no way of saying the area/volume ratio. Any suggestions? Is there a way to impose the heat transfer coefficient at the surface by a UDF so that both the temperature and the heating power will be the specified?
thank you
Radiator replacement in racecar sidepod sanchezz CFX 3 December 14, 2009 22:47
Panel radiator model Aleksander Main CFD Forum 3 May 9, 2009 15:31
Car Radiator Modeling PascalouM CFX 1 June 27, 2008 04:38
how to place a radiator? WJQ FLUENT 0 December 25, 2002 21:32
Modeling a radiator M Pownall FLUENT 0 December 10, 2000 08:56
