Combinations of zone types
Old   July 19, 2005, 04:53
Default Combinations of zone types
Sascha Behrens
in a fluent course we were told about which combinations of zone types to use and which not to use. They said there are combinations that work better than others. But i´m not sure whether i still got it right. So my question is: if i use a velocity, what do i use for the outgoing material? A pressure outlet or outflow?
Hope you can help.
thanks
sascha
Old   July 19, 2005, 08:37
Default Re: Combinations of zone types
Jason
Probably pressure outlet, but it depends on your problem.
Outflow is pretty much only good for pipe flows. It assumes fully developed flows, which is a VERY limiting assumption.
Odds are, the pressure outlet is what you should use.
Hope this helps, and good luck, Jason
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
zone types Naghman Khan FLUENT 5 July 24, 2007 03:02
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
