help: How can I import a source?
Old   June 30, 2005, 14:32
Default help: How can I import a source?
May Huang
How can I import a source term to the momentum equation? The source is saved in a file. It is a constant at each node, but different from node to node. I use UDF. But it will read the whole file at each node at each iteration. It wastes a lot of time (My grid is 1728x96).
Old   September 5, 2011, 05:49
Ayan
ayannath23 is on a distinguished road
Hi!
Did you got any solution to the problem?
ayannath23 is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
