Simple question to Window XP Fluent user
Old   August 19, 2005, 12:05
Default Simple question to Window XP Fluent user
Aireen
When I started my fluent from microsoft visual c++ toolkit 2003 command prompt window, this is what it says on my fluent window:
Welcome to Fluent 6.1.22
Copyright 2003 Fluent Inc.
All Rights Reserved
Loading "c:\fluent.inc\fluent6.1.22\lib\fl_s117.dmp" Done. Loading "C:\Documents and Settings\Proj1/.cxlayout" Done.
Does anyone get the same/similar message? I'm trying to figure out why I can't compile my udf. I've done all what are suggested in the manual/discussion forum. Pls help.. I'm stucked now.
Old   August 20, 2005, 13:50
Default Re: Simple question to Window XP Fluent user
razvan
These are perfectly normal messages. There is nothing to be worried about.
Best wishes, Razvan
Old   August 21, 2005, 07:51
Thiyagarajan
if u r facing difficulties in compiling the UDF, reinstall microsoft VC++ with 'set environment variable ' option checked. Please look at the following link for more details: http://www.fluentusers.com/support/i...nfaq/nmake.htm
bye regards Thiyaga.
Old   August 22, 2005, 10:36
Aireen
Thanks. But I don't know if I am using parallel or serial. My computer is connected to LAN server but not connected to any other computer.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Question about user defined memories in FLUENT 6.3 lordofnoldor FLUENT 0 August 18, 2011 10:17
Simple FLUENT CFD question Boo FLUENT 0 July 17, 2011 22:34
Commercial software question (user viscosity) Jeff Main CFD Forum 2 July 20, 2002 10:41
Question on openning mesh from Fluent Derek Jing FLUENT 5 April 22, 2002 15:55
