display filled contour of temperature gradient
Like Tree2Likes
  • 2 Post By helper
Old   August 22, 2005, 10:02
Default display filled contour of temperature gradient
Frederik
Hi ,
I have a 2D temperature distribution in the domain and I want to display temperature gradient profile (filled coutour) ... any body can tell me how can I get this distribution as a contours in all the domain .., and how to specefy the component of the gradient vector dT/dx ,dT/dy....
thanks in advance friends... frederik
Old   August 22, 2005, 14:10
Default Re: display filled contour of temperature gradient
Masood
hi fredrick
in the display menu goto contours. then from pull down menu slect temprature. and check the filled option. and u will get the temprature cotours.
chao...
Old   August 22, 2005, 15:05
helper
You can have access to the temperature gradients if you activate the "expert" menu. This is how to activate it. In the TUI ("/solve/set"), type "expert" and say "y" (yes) to the propmt saying "Keep temporary solver memory from being freed?". Do one solver iteration, and you will find temperature gradients in the drop-down list in the Contours/Derivatives panel.
nenazarian and YASHA like this.
Old   August 22, 2005, 18:23
masood yooceframandi
dear helper! would you tell me please,where did you read about this way!i mean "solve/set/expert...".would you tell me please? and then,i did that but i cant plot dT/dX contour because an error occurs.why? regards
Old   August 23, 2005, 05:42
Frederik
Dear helper thanks a lot for your answer ...
but what I want to obtain is countour of temperature gradient for a transient simulation after at t= 2.5 s..
should I use "solve/set/expert and run the iteration for only one time step ,??
regards frederik
Temperature gradient in CFX Chander CFX 5 January 7, 2015 03:00
distoring the colours when overlay unfilled contour on filled one s.azizi FLUENT 0 August 19, 2011 20:23
how to perform temperature gradient on a particle (Thermophoretic Force) wwt650420 FLUENT 3 March 23, 2011 02:10
Temperature gradient macro ameyadurve FLUENT 0 October 3, 2009 08:46
Question on Face Temperature Gradient Tomasz Didenko FLUENT 1 June 27, 2003 04:30
