UDF COMPILE
Old   August 10, 2005, 03:27
Default UDF COMPILE
nasser
I had error about "nmake" but I installed VC++ then my problem solved Now when compile udf the following message "cannot find specified file" appear on the consul window.
please help me.
Old   August 10, 2005, 05:13
Default Re: UDF COMPILE
Vinod Dhiman
Hi
I didn't get you properly. "cannot find specified file" error occurs if you just type the name of compiler and no source file name, or if the dependencies are not fulfilled. Like, you may not have udf.h in the directory where you have your file.
Vinod Dhiman
Old   August 10, 2005, 05:33
pUl|
There is no need to have header files in the same directory as the source.
pUl|
Unless of course, you wrote it up...
Old   August 10, 2005, 05:40
Vinod Dhiman
Yes, there is no need to have it in the same directory, provided the path to header file is specified in path variables, else its must.
Vinod Dhiman
Old   August 10, 2005, 11:49
zubier
hi all i want to know how to install MHD in FLUENT thanks alot
Old   August 16, 2005, 17:01
shiva
looks like u havent set the environment variables of ur C++ package and then start fluent from the compiler prompt and working directory.
Old   August 25, 2005, 01:06
Alper Albayraq
Hi
Shiva is right. It is better to use Visuall c++ 6 installed in your computer. And when you want to install it you must check a box which set the enviroment variables.
regards, Alper
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
