how to incorporate variable properties
Old   September 1, 2005, 02:33
Default how to incorporate variable properties
Shashikant
i want to incorporate variable fluid property in fluent my question is how do i achieve it. i am new user of fluent. the AIM is to evalute all physical properies of fluid at every node, after every iteration, and use it for next iteration. can UDF do this
Old   September 3, 2005, 09:09
Default Re: how to incorporate variable properties
Saad
Yes, I think a UDF may do it. You have to select user-defined for each variable thermo-physical property. in the Material panel.
Sincerely, Saad
variable composition mixture properties Neser25 CFX 6 August 17, 2020 14:19
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
