Compute Node Encountered Error
Old   November 23, 2009, 18:15
Default Compute Node Encountered Error
mfa
Faridul Alam
mfa is on a distinguished road
I am trying to run a steady state simulation of Aircraft Icing.The Mesh was generated in Gambit. I am trying to run the case using SST K-Omega model and I am running it in parallel.
But it's showing the following error messages:
# Primitive Error at Node 1,16, etc: receives segmentation violation
# compute node encountered error.
The grid check in fluent was ok.
Can you please tell me the root of this error.
Thanks,
Farid
mfa is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 13:29
a question of open ".cas" and ".dat" files fanzhong Meng FLUENT 4 May 15, 2006 11:40
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
