September 15, 2005, 15:46 |
Help required...udf
Hey guys,
I have an 2d L shaped pipe.fluid enters from the side horisontal part of L and makes a 90 degree turn and goes out of the top section of the L. I was using variable inlet velocity using the udf example provided in the manual. I was getting good results. Now I changed the L section to a U shape.with fluid flowing down from the right vertical part and making a 180 degree and flowing out through the left vertical. I used the same udf in the manual with changes in the x and y system. But now somehow this variable inlet velocity is not being taken. I dont understand the reason. Please help me out Thanks in advance Derick |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 20:55 |
URGENT help required regarding UDF operations in Fluent | Lexicon | FLUENT | 0 | April 5, 2010 13:48 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
