UDF Error!
Old   September 16, 2005, 15:52
Default UDF Error!
Srivatsan V. Rajagopalan
Hello I am writing a pdf for changing the Drag coefficient equation that is being used by Fluent.
While I interpret the udf in Fluent solver, I get a "PARSE ERROR"..
Can somelet me know what is a PARSE ERROR! This is what I get: "Error: C:\Documents and Settings\SriKrishna\My Documents\Thesis\Srivatsan\Flat\New_Cd.c: line 1: parse error."
Old   September 18, 2005, 09:30
Default Re: UDF Error!
rawin
check your udf.It may have error such as missed semicolon( or other c compiler error.
Old   September 19, 2005, 08:34
Joey
I think you need an editor of c. You must edit your c code in the common text editor. Once I met this error. I changed my editor, and then the error was gone.
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
